1 - 9 of 9 Posts
Just a quick bit of information that may help others.
I replaced the power steering damper strut, a couple of days ago, and the difference to the accuracy of the steering is huge. It took 20 minutes and I couldn't believe the improvement, no more leaping and hopping on a bumpy road.
I bought a Bilstein steering damper from Rimmer Bros. and it is worth every penny.
Pierre3.
If you really do have death wobble as you say, I would be careful with just writing off the steering stabilizer being the fix. Most of the time, an upgraded steering stabilizer will just mask the true problem. If I were you, take a close look and test the balljoints on both sides of your rover. Then check all the tie-rod ends for the drag link and anti roll bar links and bushings.
don't forget to get your wheels balanced as this is the real issue for wheel shimming(poor tyre ware most likely brought about by poor steering components)?
The Rimmer bros video series on Death Wobble, 3 parts, at least shows the cheapest to most expensive way to approach the repair. I never did find the 4th part mentioned in part 3.
Don't forget an alignment if you are overdue or showing tire wear. I would do that anyway just so you start from a known good position.
Thanks for all the replies.
My tyres, tracking and balance are all correct as I have just fitted new Pirelli road tyres, and I had those things done at the time of fitting the tyres.
But, I will have a look at the issues mentioned by DaGlitch over the next week or so. I will be replacing the drag link and anti-roll bar bushes fairly shortly.
But, the vehicles doesn't wander anywhere near a badly as it did before I changed the steering damper.
Pierre3.
Tyres, wheel nuts, spigot rings, balanced wheels, steering damper (but DaGLitch's comment is spot on, and when I got mine my damper was covering a whole load of issues), anti roll bushes, dampers, track road ends/ drag link, radius arm bushes, panhard rod. (if you have lift or coil conversion then there's probably a few other things to consider
It's easy to follow the Rimmer videos sequentially and replace stuff that doesn't need doing I know I did :eek:) If you have poly bushes in the radius arms start there... after six months of messing that's what did it for me - that and changing the wheel nuts from what the PO gave me for a new set.
I will follow these suggestions when I get the vehicle in for a service shortly. I will replace the anti-roll bar bushes and track rod ends first, and I have already asked my garage guy to order the parts. They should arrive in a week or so.
Thanks for the advice, much appreciated.
Pierre3.
I had a similar condition, I started by rotating the tires, then replaced the steering damper ( which I learned in hindsight that it only helps with steering wheel “kick”) then the sway bar links and bushings, finally I took the car to a specialist, he test drove the car, and first thing he said; tires, but I protested saying I just rotated them and it didn’t work, but he insisted.
Only when he raised the car off the pavement ( which I did not do) did I see the belts had slipped on one of the tires, and that thing looked alien!
Needless to say: after putting on my winter set, all is good.
1 - 9 of 9 Posts
