Hi everyone!
We are taking the '06 RR to the dealer today for service for the first time since buying it used.
We have a few gremlins which need to get worked out:
1. The lights on the center stack are not working
2. The main dash lights flicker when dash dimmer switch is a "bright"
3. Check engine light with a "left bank running lean"
4. "Reduced Engine Performance" when the cruise control is on
I am also wondering how to find out if all of the TSB work has been done and if there are "optional" TSB's we should be discussing with the service manager.
I will also ask him to address the peel on the window switch and steering wheel.
Any other advice is most appreciated.
Dave
No we did not know this when we bought it. The lights problem started Saturday evening as did the check engine light. The degraded performance issue occurred Monday while driving on the highway. The peeling we saw but understood it to be normal use for a RR.
