A plug for the Prestige Land Rover in Paramus, NJ and the service manager Jeff. Very professional, very easy to work with.
Under Warranty
Replaced:
Exterior door handles (4) due to paint peeling
Steering wheel due to delamination
Driver door panel window switch bezel due to delamination
Belt tensioner and belt as per TSB
Serviced:
Applied LTB00144 for Sirius lockup
Repaired short in passenger door that was causing the dash light dimmer and center stack light failure (2.5 hours!!!)
Reset Airbag warning
Complete inspection - Free of charge
Brake fluid flush - $159.88
It appears that I am doing brake pads on Thursday AM as the turkey bakes. They are at 3mm and the lights have not turned on yet. Bought the pads. I still have all my wonderful heavy lifting jacks and stands from my Lagonda days. Should be fun....
The last open issue is for absolutely no reason that they could find, the "Reduced Engine Performance" shows up between 60 and 70MPH. There is no reduced performance and I can get very nice acceleration and the message disappears after a few moments. Dealer was unable to recreate and the IDS showed no issues.
Also recommended fuel injector cleaning. I declined, figuring I'll throw in a couple of cans of Techron first. Is this the right move?
Dave
Under Warranty
Replaced:
Serviced:
Dave
