1 - 10 of 10 Posts
Got my OME kit to convert to springs. (Yes, I know EAS rides better, etc etc, I'm keeping all the bits JIC I hate it and hot the lottery)
Atlantic British deactivation instructions are fairly clear except:
3. Remove (2) Green/Yellow air suspension relays and fuse located under front passenger seat.
You can't miss the relay (it's about the size of an old 8bit Nintendo cartridge) but I don't know which one is the fuse.
Any help would be greatly appreciated!
Jonathan
1995-2002 Range Rover Classic
right side seat, remove side panel and all is there to see including eas ecu, you can disconnect it also if you would like to do so. no harm no foul
Some photos under the passenger seat.
First photo is of 2 30A fuses near the rear of the seat area. I took both these out.
Second is a side shot I think showing the relays that need to come out (yellow and green) and another 30A fuse. I took the fuse out as well.
Third photo is looking straight down to where the EAS ECU was and 2 connections that were next to the ECU (towards the center of the car. I left these connected.
To summarize: I removed all the fuses I saw under the seat, 3 30A ones. Also removed the green and yellow relays and the EAS ECU.
I am still installing the springs (had to use coil compressors which get in the way and make the process a pain) but will post later to see if everything I disconnected was correct.
yellow white and green relays as well as the large fuse on the 70 amp carrier is all you need to remove, the others you mentioned are for the power to the right seatas well as possible seat heater if equipped.
Thank you, likely saved me some time.
I regret yanking my EAS, I’ve got the OME springs in, which are fine, but man, I miss the self-leveling.
Thankfully, 95classiclwb is going to help me put it back, as he’s the one that ripped it out in the first place;)
sorry man, no speak English.
Discussion Starter #10
Finished the OME swap, rides fine but loses a touch of magic.
****, I never want to see a coil spring compressor again though.
1 - 10 of 10 Posts
