Hello there, I have 2006 HSE with a dashboard that won't light up. I've 'fiddled with' the rheostat or dimmer switch that should control the brightnes of the light(s), the battery is good and I've checked the fuses all to no avail. Suggestions for a cure please. Regards, RangieIan.
Are you talking about just the green background lights that illuminate the needles on the speedo ect? or do you mean all the lights including the led`s that show show vehicle function errors ? does the speedo, fuel gauge and rev counter work ?
2007 4.2 Supercharged Vogue SE
Hi Ian did you have any joy in this?
2007 Range Rover 4.2 SC V8
Hi Ian, Likewise:did you get any joy?
I am searching for a resolution to a similar issue.
@Jools you should create a new thread instead of piggybacking on an unresolved, unclear, 2 year old thread so you can clearly define your issue and what you have tried already to fix the problem
