1 - 12 of 12 Posts
I've got a problem with the rear offside light on my RR. The dash display shows 'Rear Light Failure' but the bulb is fine and works in the other side. When I ran a multimeter across appropriate the terminals in the connector block it shows a constant 0.5V regardless of whether the lights are switched on or off. When I do the same on the near side I get 0V when off and 12V when on (which is as I would expect.)
The MOT is now due and as it stands it's a fail so I need to sort this out asap - any suggestions as it's got me stumped.
what about the license plate light????
That works fine as does all the other lights.
That comes up as Tag Light.
Did you ever fix this problem? Mine just started doing the same thing. I have read that there have been some similar issues related to trailer lighting but mine is not wired for trailer lights.
I have had a similar issue for years. When I turn on the rear fog lights, it throws the error to the message board that I have a light out, but I do not. Annoying. My theory is that there is a very minor wiring issue probably ground in the tailgate that causes the resistance to fluctuate. If I replace the bulb, it will stave off the error for a little while. I would check your grounds in the back...
Sometimes as bulbs get older the resistance (ohms) change and that is possibly what's wrong. Longshot. True for my Grand Cherokee.
I replaced the bulb that shows the error, right rear. I still got the bulb failure message. Then I swapped the bulbs from left to right and got the same right rear bulb failure message. The connection is clean. It must be a ground issue but I will have to get RAVE so I can figure out how to start tracking this down. Any tips appreciated.
Just wondering if you solved this.
Change the bulb even if its working. Resistance off due to age.
1 - 12 of 12 Posts
