FOUNDING MEMBER
On my 2004 Range Rover there is a red light similar to the alarm one on the rear view mirror, that is in the middle next to the windshield. What is it for, I have not seen it flash or anything.
Also, at time the workd "PROG" flashes once in the multi display after startup. Is this something with the Radio or Remote Key.
marc
FOUNDING MEMBER
Is my 04 Rover the only one with this red light in the dash?
It is the middle next to the front windshield.
G
Guest
that other red "light"
Your are probably referring to the sensor that detects sunlight entering the car via ?IR ?UV light, I think it is some kind of photo-receptor and adjusts the air-conditioner so, it doesn't flash, it does look similar to the alarm light beneath the rear-view mirror I agree. It is located on the dash board mid way just behind the windscreen and is very conspicuous.
Murray
G
Guest
Do you know specifically how it alters the A/C?
Also, I am not sure I understand the heating system, when I hit the heating system to go on automatically (the outside temp is lower than the temp I set the dial to), the A/C goes on. Why would the A/C go on when it's trying to heat? I wind up turning off the A/C. Is this correct?
dG
