Does anyone have the instructions for a 2006 Range Rover sport SC, chapter for the Cylinder Head RH removal and install.
I have the LH side from a manual i got from ebay but RH is missing. See attached first page for the LH side ScreenHunter_64 Nov. 16 10.41.jpg
I would of thought the LH and RH are identical but since its explictly calls out LH, i thnik there must be a difference, does anyone have the RH or know the difference ?
And anyone got any tips on replacing the head gasket
JACK'S GRANDAD
www.Alldatadiy.com would be your best bet for the "manual".
Not only do they list all the repair details, they have TSB's, labor guide, part numbers, and so on.
Martin
I just did the same as the LH for the RH and it was identical
15390968_10153988217572353_4982084515181424890_n.jpg 15400313_10153988217582353_6008836152278077937_n.jpg 15400984_10153988272097353_4064474328134451819_n.jpg
I measure the heads with a precision straight edge and feeler gauge, they i couldnt get a 0.08 mm feeler under it, so i think they are good.
Do they look clean enought to re-mate ? and i also lapped the valves, does that look clean enought ?
Sweet. IMG_0012.jpg IMG_0005.jpg That looks good.
Airtools! ;)
