Nope, the injectors need to come out just to able to remove the valve covers, then both cam shafts need to be removed to get to the 10 cylinder head bolts (for each head)Reading thru the manual it looks like it might be possible, I wanted to check here first.
Can the head be removed without removing the fuel injectors?
Oh i didn't realize that. i have an 09 with the 4.4. I guess the 5.0's are direct injection? Good luck with it brother.Thanks
I see the headbolts under the camshaft, Lol, I guess there is a bunch of stuff in a small space, valvecover looked tight, I will have to buy a fuel injector removal tool before I start, then.
Bmw, these are direct injection
Thanks to both of you
