My mechanic has just called to say that both the head gaskets had blown and that he can skim the heads and refit no problem. The thing is he cannot find anyone local to pressure test them once done. Do you think it would be wise to go ahead and hope that if he can't see any cracks then they will be OK? Also I bought the uprated (and far more expensive) fibre gasket set to replace the tin ones with. Is there anything special he should note or do with these or are they a straight replacement?
Thanks for your help so far with this.
Whereabouts are you?
Sorry. I really should fill my profile in. I am in South Wales, United Kingdom.
