Hi Peeps!
The cup holed which is in the passenger side dashboard of my 4.4HSE has never worked.
I have just removed the entire unit and there is a large coil spring which sits in a cradle and looks like it should push the assembly out once you have pressed it in slightly.
Unfortunately, it just sits there doing nothing.
Has anyone any idea how and where the spring should be attached?
If you bring it over to me, I'll fix it for you in 3 minutes, but hard to describe how to do this: the coil spring sits at the back of the cupholder and the coil end goes into the sleeve in the housing.
Success!
There has been a thread on how sometimes these pop-out cupholders get stuck and stop working. It started happening to mine but I just squirted some WD 40 lubricant in there a bit at then jiggled it about and it came unstuck and has worked ok since then. So I never disassembled it.
The coil spring is in its cradle, but not conected to anything. Looks like the end is broken.
Probably best to get a complete replacement unit.
