I've searched the threads and I can't seem to find the answer to this...
I'm replacing the vacuum tubes on my cruise control, but the longer tube disappears back into the firewall. How do you disconnect this? Do you access it from the engine side, or somewhere inside the cabin?
Thanks,
James
RIP Our Friend
If you are replacing it you will need to disconnect both ends. remove your knee panel, lay on your back and you'll see where it goes.
