My cruise control has stopped working. The main dash mounted switch shows no light when switched on.Can anyone tell me if this is fused? If so which fuse controls it? Thanks in advance.
If I remember right the Circuit's not fused but if you go to the Electrical Troubleshooting Manuals of Rave, Circuits section B5 there is a quite comprehensive test procedure and you only need a muliti meter and a couple of bits of wire.
My 99 hse had the same problem no light on switch to set cruise control but read through site and checked the rubber hoses to the actuator near esu and they were perished changed them and low and behold it worked..
