So I posted this over on the Range Rover board at Discoweb and all the vets put me down for using something that was stupid and supposedly unsafe. I was curious about the opinions over here, I know that many folks here are also registered at discoweb, this forum seems to be much more tolerant and open to differnt things.
For your consideration:
http://www.liqui-technik.com/kipp2_e.html
Rated at 3500 kgs, about 7700 lbs
A few weeks ago I replaced the fuel pump in my Range Rover and did get a lot of good info on how to do it from rangerovers.net and discoweb. It only cost me about $100 for pump, clamps and fuel injection line, way better than the almost $300-$600 that places are asking for the whole assembly not including labor.
A friend of mine that is a Jag enthusiast that helps me turn wrench on my Rovers occasionally got this contraption from germany for about $1200 and it is absolutely amazing. You hook it up the the vehicle and you can safely tilt it up to a 90 deg angle, they advise a bit less for larger trucks or SUVs. It uses any electric drill to turn the mechanism that does the lifting.
The reason I took my friend up on his offer to use this thing was because my air suspension is shot (but thats getting fixed tonite with replacment airsprings), its sitting on the bumpstops. So that made it difficult to pick the vehicle up by the frame high enough to have enough clearance to get under it and drop the tank easily. Otherwise I would have just jacked it up by the diffs and set it on jackstands. I was sketch about it at first too but its absolutley rock solid and built with sturdy, heavy galvanised tubing.
