Hi All,
I have 2006 RRS S/C 4.2
I want to replace the crankshaft fount seal, I see the service manual list a whole bunch of special tools, to remove and install the crankshaft pulley and seal
I have listed them at the bottom. Im wondering if anyone has had any luck using generic tools from harbour freight or else where
would this work for the seal
https://www.amazon.com/gp/product/B01AY0HLG6/ref=crt_ewc_img_dp_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Is says it does seals 21 to 64mm. What size is mine ? and do they mean diameter or circumference or radius
Any got any recommendations ?
Crankshaft pully remover303-588
Holding tool crankshaft303-893
Adapter303-191-03
remover cranshaft seal303-D121
installer Cranshaft seal303-1100
Adapater303-1100-01
I have not done this job, but I'll bet that that Amazon tool will be adequate. Probably can be done with a hook type thing and use the old seal or big enough socket or piece of pipe to press the new one in. The pulley will probably remove with a common puller. Holding the crankshaft might be a bit tricky but by using a picture of the tool and the instructions you can probably do a work around.
