Crankcase Position Sender, can someone what the oms reading should be?
HI, P38 1998 4.6. Can someone tell me what the correct oms reading should be for the CPS, i had a starting problem, removed CPS and got a reading of 1.2. Also cleaned maf sensor, and P38 fired up straight away with no fuel starvation, where before it would fire up and only run for around 5 seconds. But now running well.
But is this measurement for CPS correct. Thanks
