Another technical question:
The crankcase gases are routed back into the intake system. I disconnected this pipe from the air filter housing because I thought this way the engine doesn't get hot gases and doesn't overheat so fast. Does this pose a problem to the PCV valve ( is there a vacuum system that suffers from disconnection of the pipe ?).
Regards,
Christian
Regards,
Christian
