My 2011 Range Rover HSE will crank over, but won’t start. As I was driving it just randomly quit and won’t start again. Any suggestions??
Hi Welcome to the forums! Check fuel system pressure using computer diagnostic tools (there is no port to attach a gauge). The 5.0L engine has a 3 stage high pressure fuel system (similar to a diesel engine) with over 2000psi on fuel rail. If it starts after sitting for a while, injector leakdown is a possibility. You can also run fuel prime routine in diagnostic computer to see if pump runs.
Another thing to check is loss of coolant, which is a sign of potential overheating/leak.
Also check for any stored DTC codes.
