1 - 16 of 16 Posts
How does the CPO warranty work if there are no service records?
Looking to buy a 2016 RRS V8SC with 60k miles. Carfax shows 3 owners and absolutely ZERO service records.
The second owner bought it CPO, owned it 9 months, then the third guy owns it 5 months. Carfax shows no service records. I thought in order to sell CPO it had to have service records.
I'm looking to be owner #4, but only if the warranty will be valid. LLNA said that it's valid till 10/2022, but I need to know if it'll cover issues, seeing there's no service history.
Am I an idiot for trying to be the 4th owner of a used RRS with 500HP?
Waffle,
I would not say that you are an idiot, but I would be really skeptical about this rig. 3 owners in less than three years and no records of any service suggest that there is probably more than meets the eye. I would keep on searching.
Best of luck.
Steve
· RIP Our Friend
Waffles, you are confused about what what must be reported in a Carfax. Nothing must be reported to Carfax. Carfax does it's own research through public records. Police reports of accidents are transferred into a database for statistical research by the NTSB, Insurances and anyone else that have use for it.
All licensing transactions and title changes go through each states department of licencing data bases. Insurance companies report totaled vehicles to licensing departments so the titles can be tagged as such. If a totaled car is purchased back by the owner, the title is marked "salvage." If a car is sent to scrap the company recycling the vehicle must obtain the title and file a notice of destruction. Parts yards must file with licensing.
A Carfax report is only as good as the info available in public records. If a car is in an accident and no police report is filed and repairs are handled by the owner... there is nothing for Carfax to find.
To be blunt, service has nothing to do with whatever third party warranty is used to CPO a vehicle. There are service records for this rig...with whomever did the services and charged the owners.
That may be true, but out of the hundreds of carfax reports reviewed in last 6 months, I don't recall a single LR/RR without service entries.
I'd love an answer from an experienced individual regarding the CPO warranty. And how strict the policy is regarding service records.
I mean say I purchase the car and the engine blows. Will I have to hire Sherlock Holmes to trace down service records, from a cash only shop, or will LRNA do that? I'm really looking for some deep insight in this realm.
I am looking for a 16 or 17 SVR. And I have come across a few with NO service history records on the CARFAX. One vehicle was at a Land Rover dealership with NO records on the CARFAX. But they did have the records at the dealership for this vehicle. Like RRToadHall, everything is not reported on a CARFAX or other reports.
2019 Range Rover Sport SCV8 ATB (L494)
The vehicle has had three owners is less than 3 years and service history is unknown. I'd stay far away from it - find another similarly spec'd one.
Discussion Starter · #7 ·
I had a guy drive out to scan the vehicle. No dash light, but here's the report. He said it's in good shape and no other concerns.
What do you guys think about all the communication codes? The PCM codes are kind of alarming.
[h=1]Autologic Quick Test Report[/h]
ManufacturerLand Rover
VEHICLERange Rover Sport
L494
AJ V8 5.0 SC Petrol
Year2016
Country/AreaNAS
Autologic informationAutologic Serial Number A022826
Land Rover Software Version 3.83.0
Main Software Version 6.10.6
Time/Date13:23 28/01/2019
[HR][/HR]
[h=2]20 MODULES WITH FAULTS[/h][h=2]10 MODULES NOT RESPONDING[/h][HR][/HR][h=2]INSTRUMENT PANEL CLUSTER[/h]2 Faults Present
U0001-87HIGH SPEED CAN COMMUNICATION BUS.
Missing a message.
U0011-87MEDIUM SPEED CAN COMMUNICATION BUS PERFORMANCE.
Missing a message.
[HR][/HR][h=2]SIDE OBJECT DETECTION CONTROL MODULE LEFT[/h]1 Fault present
U0010-87MEDIUM SPEED CAN COMMUNICATION BUS.
Missing a message.
[HR][/HR][h=2]PARKING BRAKE MODULE[/h]2 Faults Present
C2008-13LEFT MOTOR.
Circuit open.
Missing a message.
[HR][/HR][h=2]TIRE PRESSURE MODULE[/h]1 Fault present
Missing a message.
[HR][/HR][h=2]TELEMATICS CONTROL UNIT[/h]1 Fault present
Missing a message.
[HR][/HR][h=2]GATEWAY MODULE[/h]1 Fault present
U0037-87VEHICLE COMMUNICATION BUS B.
Missing a message.
[HR][/HR][h=2]IMAGE PROCESSING MODULE A[/h]1 Fault present
B1286-97INTERIOR MIRROR.
Component or system operation obstructed or blocked.
[HR][/HR][h=2]BODY CONTROL MODULE[/h]6 Faults Present
B13D3-84LEFT - DAYTIME RUNNING LAMP AND POSITION LAMP - CONTROL.
Signal is below allowable range.
B13D4-84RIGHT - DAYTIME RUNNING LAMP AND POSITION LAMP - CONTROL.
B14D8-11LEFT TRAILER SIDE LAMP.
Circuit short to ground.
B1C45-67FRONT WINDSHIELD WIPER PARK POSITION SWITCH.
Signal is incorrect after the event.
Missing a message.
U2300-54CENTRAL CONFIGURATION.
Missing calibration.
[HR][/HR][h=2]IMAGE PROCESSING MODULE "B"[/h]3 Faults Present
B108E-31DISPLAY.
No signal.
B12BE-31FRONT LEFT CAMERA.
No signal.
Missing a message.
[HR][/HR][h=2]POWERTRAIN CONTROL MODULE[/h]6 Faults Present
U0416-68INVALID DATA RECEIVED FROM VEHICLE DYNAMICS CONTROL MODULE.
Event information.
U0402-00INVALID DATA RECEIVED FROM TRANSMISSION CONTROL MODULE.
No sub type information.
P21A3-85CYLINDER 8 - AIR FUEL RATIO IMBALANCE.
Signal is above allowable range.
U0121-00LOST COMMUNICATION WITH ABS CONTROL MODULE.
P2066-00FUEL LEVEL SENSOR B - CIRCUIT RANGE/PERFORMANCE.
P0461-00FUEL LEVEL SENSOR A - CIRCUIT RANGE/PERFORMANCE.
[HR][/HR][h=2]CHASSIS CONTROL MODULE B[/h]1 Fault present
Missing a message.
[HR][/HR][h=2]ANTILOCK BRAKING MODULE[/h]1 Fault present
U0001-81HIGH SPEED CAN COMMUNICATION BUS.
Invalid serial data received.
[HR][/HR][h=2]PHONE CONNECT AND VIEW[/h]3 Faults Present
U0001-82HIGH SPEED CAN COMMUNICATION BUS.
Alive/sequence counter is incorrect/not updated.
U0011-82MEDIUM SPEED CAN COMMUNICATION BUS PERFORMANCE.
U1A4B-47CONTROL MODULE MICROPROCESSOR B.
Watchdog/safety failure.
[HR][/HR][h=2]CHASSIS CONTROL MODULE[/h]2 Faults Present
Missing a message.
[HR][/HR][h=2]TRANSFER CASE CONTROL MODULE[/h]2 Faults Present
Missing a message.
U3000-47CONTROL MODULE.
[HR][/HR][h=2]SIDE OBJECT DETECTION CONTROL MODULE RIGHT[/h]1 Fault present
Missing a message.
[HR][/HR][h=2]AUXILARY CONTROL MODULE[/h]1 Fault present
Missing a message.
[HR][/HR][h=2]RESTRAINTS CONTROL MODULE[/h]1 Fault present
Missing a message.
[HR][/HR][h=2]HEATING VENTILATION AND AIR CONDITIONING MODULE[/h]2 Faults Present
B1031-87REAR LEFT SEAT HEATER.
Missing a message.
B1033-87REAR RIGHT SEAT HEATER.
Missing a message.
[HR][/HR][h=2]POWER STEERING CONTROL MODULE[/h]2 Faults Present
Missing a message.
[HR][/HR][h=2]MODULES NOT FITTED OR NOT COMMUNICATING[/h]
LH SEATBELT PRETENSIONER CONTROL MODULE
REAR CLIMATE CONTROL MODULE
DRIVERS REAR DOOR CONTROL MODULE
ELECTRIC POWER INVERTOR CONVERTOR
GENERAL PROXIMITY SENSOR
RH SEATBELT PRETENSIONER CONTROL MODULE
RUNNING BOARD MODULE
NAVIGATION CONTROL MODULE ASIA
BATTERY ENERGY CONTROL MODULE
CRUISE CONTROL MODULE
[HR][/HR][h=2]MODULES WITH NO FAULTS STORED[/h]
FRONT CONTROL DISPLAY INTERFACE MODULE
FRONT CONTROLS INTERFACE MODULE
FRONT CONTROLS INTERFACE MODULE - C
REAR GATE/TRUNK MODULE
STEERING ANGLE SENSOR MODULE
DRIVERS DOOR CONTROL MODULE
DRIVERS SEAT MODULE
PARKING AID MODULE
REMOTE FUNCTION ACTUATOR (KEYLESS VEHICLE MODULE)
HEAD UP DISPLAY
PASSENGER SEAT MODULE
OCCUPANCY CLASSIFICATION SYSTEM
FRONT CONTROLS INTERFACE MODULE - B
PASSENGER DOOR CONTROL MODULE
PASSENGER REAR DOOR CONTROL MODULE
REAR DIFFERENTIAL CONTROL MODULE
ALL TERRAIN CONTROL MODULE
GEAR SHIFT MODULE
Last year I bought a 2014 cpo f-type. Engine blows up and warranty denies repair until I can provide the service records. I’m like wtf? It’s cpo and how would I have the service records if I wasn’t the owner? Service Advisor was telling me it’s a $48k repair and warranty company doesn’t want to flip the bill. To make a long story short the finally cover it once I show proof of oil changes at proper intervals. What a cluster duck
Discussion Starter · #10 ·
Thank you so much for the insight. This is exactly what I was looking for. The car I'm looking at was sold CPO at 40k miles. No service records before nor after (from the owner or carfax). I guess if I bought it at 60k miles and started an oil change cadence, maybe just maybe I'd get lucky if major issues arose.
Anyway, after 2 weeks, $200 inspection, and $10k drop in asking; I passed. I do not deny that it could've been a winner though. I love me a good deal.
· Premium Member
I bought a2014 RRS SC Dynamic CPO, no service records on the Carfax, but lots of them through the dealer. The dealer (actually from Louisiana) does not use Carfax, but the Land Rover system.
Ask the dealer for the service records, they have them if it is CPO.
I didn't have that many codes when my battery died/low on my 06 Jag. And that was with the "Christmas tree" dash light show. If you have ever seen it, it flashes every light in the dash and freaks out every canbus on the car.
Gut feeling about this RRS........Run!
2019-2021 Range Rover Sport
Just want to comment on all of the above faults.. I have a 2019 f pace and a 2019 rrs the f pace is currently in the shop for 24 faults I did the scan and a bunch of the can bus failures above as well as the multiple modules with invalid info also show up on the f pace it only has 1800 miles on it.
my Range Rover has 8 of the various can bus codes as shown above, one was permanent and the others were intermittent and it only has 187 miles on it.
It is very strange that a bunch of JLR vehicles are having these codes not sure if they are serious or not but i do know that we all are having to bring our trucks in to fix glitches and i dont believe it is only due to the software versions. I would bet that if everyone would have their vehicles scanned even if they are not having symptoms many of the above vaults would show up.
With that said I would have passed on it as well better safe than sorry. I would suggest in the future as whomever scans the vehicle to let you know if they are intermittent, permanent or historic faults they can also tell when the faults happened at what mileage.
Out of curiosity did you call your local dealer with the VIN and ask if it was showing as covered under warranty? If so did you not believe them? That's about as far as I would have gone so just wondering. If the dealer said it shows as under warranty in their system I wouldn't have thought twice!
Discussion Starter · #16 ·
I did not contact any dealers. I sent the VIN directly to Land Rover NA. They said that the vehicle indeed had the transferable CPO warranty until 10/2020.
If this is where you would've pulled the trigger without further investigation, then you sir are more of a gambling man than I, or you just have more money, because here is the part that will surely come into question when the time comes...
The Land Rover Approved Certified Limited Warranty covers vehicles for up to seven years or 100,000 miles, whichever comes first, as long as the vehicle is serviced as recommended by Land Rover.
I then replied to LRNA asking about the importance of service records in case of warranty work.
Direct reply...
Thank you for your response. The warranty could be effected if there is an issue with the vehicle, and it is determined the issue is caused by improper maintenance. This is a risk a consumer takes when not purchasing a CPO from an authorized retailer. Documentation of maintenance is very important as proper maintenance will keep a vehicle performing as intended.
I dunno. Could be hit or miss.
1 - 16 of 16 Posts
