Just bought a '99 Bosch 4.0SE (133k miles) that has an overheating problem. A few problems:
1. The PO neglected to tell me that it is stuck in park. I disconnected the linkage under the truck and manually shifted into 'N'. The brake lights come on. When I put the key into the 2nd position (accessory mode?) I can move the shifter out of park. Is it a solenoid or something?
2. There is a noise that comes from the ABS pump whenever I hit the brake. The ABS light, (!) parking brake light, and TC traction control light all come on when I hit the pedal. No ABS fault, but everynow and then a 'Traction Fault" will pop up. The brake pedal feels fine. I havent driven it though. Could this be a bad ABS Accumulator?
3. PO says it overheats, and I checked the oil and it sure enough is milky. Bad head gasket I assume. Is there anyway to check that it is not a cracked head/block? I dont want to spend money on the gaskets if I can use it towards a new head/block.
4. Idleing. PO said it wont idle. I cranked it over, and it wouldnt idle and shut off. I didnt really try though, since the oil is probably no good and I didnt want to damage it. Plus there is a bad exhaust leak somewhere, I could barely hear, sounded like a jet engine. What would make it not idle correct? Could it be from damage to the engine from overheating?
5. Somewhere along the line, suspension was changed to coils. I would like to maybe try and sell the compressor/valve block to try and recoupe some of my expenses. Is there anyway to test and make sure these work? Can I remove them and still drive normally with a coil conversion?
Thanks a lot, I have been doing a lot of research on here, and just want to be sure before I spend any $ that I dont have to.
