OK, so I pulled the right front door off the other day because I wanted to see some things.
1: wanted to see why my front passenger window rattled (only when all the way down). I had read some posts suggesting this was caused by a missing rubber gasket at the bottom of the window and window assembly. That doesn't appear to be my issue, any other thoughts?
2: I went ahead and pulled all the doors off to check, and see if the window mechanism looked the same.. they did. However, the "vapor barrier/insulation" in the front passenger door was ripped in half (solved with gaffers tape for now) and the rear passenger one is GONE! Any idea where I can source a replacement for these?
Picture of what I need.[attachment=0:1160heq8]door.JPG[/attachment:1160heq8]
Thanks in advance.
Get hold of Microcat it makes life much easier for finding parts
RH Front - EJD101520
LH Front - EJD101530
RH Rear - ELD100920
LH Rear - ELD100930
