Hello
I seem to have smoke coming form my expansion tank, to me it smells like exhaust but i could just be paranoid, several times recently the coolant has been forced out of the tank as the car almost overheated, carpets are wet so i am guessing o rings as referenced many times on this great site, could i loose enough coolant this way to cause an overheat?
if the coolant has been forced out of the tank would the cap be more susceptible to failure ? cause pressure issues within the cooling system as well.
there is absolutely no sign of any condensation on the oil filler cap and the head gasket was replaced (by me after the LPG system failed) only 1000miles ago, as i did the work i am not 100% confident it has been done correctly although i followed the book perfectly.
what are the other home test i could do to rule out HG and any other areas i could be looking at to test cooling system?
I read somewhere about the viscous fan failing how do you test this?
the car is an 1995 4.6 186000 miles on the clock (previous owner replaced engine at 120000 due to porous block issues back in 2002 i think)
need to be as sure as i can be that engine will be sound as i want to refit the LPG at great cost so i can use this car for a long time yet. i have no issues doing all the work i just help and pointing in the right direction
many thanks
many thanks
