I am wiring in some aftermarket gauges.
Just oil and water temp
Does anyone know what the ohms of the sensor is?
Reason I ask is my gauge is reading approx 50 degrees F hotter
Sensor number is PRC7918
The gauge instructions say
"Water Temperature Gauge ( 100 - 250 "F) = 560 - 37 ohms"
Is it compatible? If not, would that be the reason the gauge reads hotter?
1995-2002 Range Rover Classic
the rave gives you a complete range of values thru various temp readings.
