A 2000 Bosch 4.0. New radiator, replaced coolant, burped carefully. No signs of overheating as far as I can tell. The gauge is at the middle, slightly towards the cold. All of a sudden the gauge goes all the way to the left (cold). Keep driving, all of a sudden the needle moves, quickly into the middle position.
I am suspecting an electrical issue (bad connection, bad ground) or a bad sensor. Where should I start? Is the sensor accessible without removing the intake?
Hi,
Any error code?
I think if it is a faulty sensor or wiring issue "before" the sensor, there is an error code showing up (p0117 / p0118).
Edit: can you read the temperature from an Autologic, Nanocom or any other equipment? This could help narrowing the issue to the sensor side or to the gauge side.
I'll read the coolant temp via OBD II. I remember that the coolant temp was flaky last time I did an OBDII read on it.
Maybe the sensor, then.
You don't have to remove the intake. Removing the a/c pump or the alternator could help, though.
what happens if you overcharge your car ac? Getting the answer by visiting Autoguysland site.
I would check the the thermostat first. This sometimes is caused by stuck open thermostat, or a thermostat that was replaced incorrectly.
I'll check the temp with ir gauge. It feels like an electrical problem, because I drive for a while and it shows "cold", then all of a sudden jumps in the middle in an instant. It feels like a loose wire or ground somewhere. But then, could it be sticky thermostat that moves when I go over a bump?
I don't think so.
A bad connection will cause a low reading, so that's the first thing to look for. The gauge reading is electronically stabilised, so there's no way a bad thermostat or other coolant problem could cause it to jump. But an open contact will give a default reading of -40°C.
Filip
