I did oil change today and noticed some dryed coolant residue around the thermostat body (2006 hse).
I replaced coolant tee a couple of years ago ... so I’m thinking the plastic thermostat body is cracked/leaking under pressure ? If there is any coolant loss ... it is minor (the reservoir is a little lower than the min line when cold- but not much).
Time to replace the entire plastic body ? Or just thermostat and o-ring ?
If you think the O ring is the issue that is a quick fix but the housing is not much more time or money. I did all the plastic after I found coolant puddeling on my 06 HSE. Once I got the part off i saw the pin hole leak. Good luck.
