2011 range rover hse non super/charger, has coolant leak had trouble seating waterpump tube seal and oil pipe seal but put tube on pump then inserted onto oil tube blindly ,felt like it went on then brittle elbow punp tiny pipe leaks but not the major leak , leaking from under vehicle probably through valley bay, im goin to replace plastic croosover pipe next thanks,,, if anyone knows how to properly install oilring seals on pump and tube greatly apreciated 3 times later, sorry for the prose, Manny
2010 SC 5.0 Range Rover MkIII / L322
I suggest to use Dow Corning 111 on all of the O ring seals it will preserve them and they will stay soft this works well for the coolant O rings
Stan, do you know if it takes x2 o-rings on the oil cooler side? The dealer part dept. says only one on each side, but the manual says X2 on the oil cooler side with an illustration of only one o-ring to further confuse...BTW I have the same vehicle and color except non SCH...
