I'm amidst about what type of coolant to use. I keep hearing different things. Can someone tell me what is the best? I don't care about price. Thanks I keep hearing dex-cool or blah blah. Anyways, thanks for the reply.
If yours is a bosch engine, the coolant that is most likely in it is dexcool. If yours is a gems engine, it should be using green oat. You can flush the coolant completely out of there and use w/e you would like. I personally prefer the green stuff.
im using this yellow stuff from NAPA right now, its simply called "extended life" says works for everything and all coolants. i do have a bosch, sorry for the shitty sig pic cant really make out the writing, i was using dex-cool, i searched rave, and nothing. and yea mag, no go on the water. i think i'll just flush the whole thing and fill it with the napa extended life, its suppose to good with aluminum right?? anyone know of this coolant??
you'll be fine. just make sure it's okay for Alum engines...which pretty much all of them are now.
Not sure if things are different in UK, but my Bosch uses OAT coolant which is an orangey/pink colour.
Also to the best of my knowledge Dex-cool is OAT. The green stuff is the older type normally used in GEMS engines.
