I have a Jap import p38 that has a KPH Speedo. But on import to the UK years ago it was converted to read in MPH. I now want to change it back to read as KPH for use in Ireland Can anyone tell me how I do this ?
regards. David
I think you need to set "Market" using Nanocom ? Also depends if the Instrument cluster was changed. The UK version reads both MPH & KPH anyway.
Super Moderator
How was it converted in the first place? The speedo is driven by pulses generated by the ABS ECU so there could be some electronics to alter the pulses or, more likely the speedo face was swapped. Does it read 70 mph when the needle is straight up at 12 o'clock?
