I just purchased a 2001 RR HSE 4.6 with 86,550. Took it to my mechanic and I found it's been castrated (switched to coils). Wanted to know should I consider switching it back to the air-ride? Any thoughts?
Yes, it is a really nice, satisfying project - not too dirty either!
Just take it step by step, Scotty is the man.
One thing to check is that the eas ecu is still there (probably is, and not a big deal to replace) AND that the associated wiring to it has not been butchered.
Apart from that, it is straightforward to do.
You might need to clear a previous fault in the ecu, so think about some diagnostic kit (which will also help you set the heights if necessary).
I'm actually doing this job this weekend on the Callaway..8)
And here you have the C11 back on Air....:dance: Now I need to get rid of those shocks, and brake rotors! Brakes will get done tomorrow....
Well done.
I can't see what make the shocks are but the rotors (brake discs) look remarkably like what I have fitted. EBC brake discs, or rather the Paddocks equivalent, which are a well respected LR brand in UK. With the matching brake pads I think that they are an improvement on the stock ones.
