I can jump wires to start the compressor, and I can use the EASUnlock software to pump it up, compressor is strong (works).
I tested voltage on pin 13 underneath drivers seat to see that the pressure switch is working properly, as it gives 12V when the tank is pumped up (works).
I also tried grounding the orange wire that comes out of the pump itself, but that doesnt do anything because there is 0V on that wire to begin with.
I have checked all the Fuses, MaxiFuses, and replaced the relay 20, everything is fine.
I think my EAS computer is working fine because it does a great job of setting the ride heights and adjusting each corner properly.
My only problem is that I cannot get the compressor to automatically turn itself on when it needs to.
In the meantime I have rigged up a switch that I can manually turn it on underneath the drivers seat but then I run the risk of overpressurizing the tank if I forgot that I left the switch on.
Anything else that I should check or any other suggestions? Your advice is much appreciated!
