Hello all,
I have a question regarding the dimensions of the Land Rover spring seat (PN NRC9700)
Here is the spring seat that I am referencing: Image, Webpage,
I have a Atlantic British Coil Conversion on my 98 p38, and I am looking to put a one inch spacer to level the front end. The setup has a spring perch adapter, which sits under the spring seat, which then sits under the spring. I want to slide a spacer above the perch, but under the spring seat. Here are photos of what I want to do.
Grey = Spring seat
Blue = Spacer
Orange = Perch
The bolts come up through the perch as well as the seat to fasten the bottom of the spring to the spring seat. I need to mill these holes out of my spacer in order for the fastening bolts to reach the spring seat.
Does anyone know the spacing and diameters of these holes?
I am asking the forum because I do not want to drop the axle, pull out the seat, and then take measurements if there is someone on here who already knows; if it's necessary I will end up doing it though. I currently have designed a 2.75 inch spacing for the holes based on some info that I got from a discovery forum (see picture below). I still want to double-check before I go and mill out holes that are designed for a different seat.
Grey = Spring seat
Blue = Spacer
Orange = Perch
