Hello,
I have Clunking/Knocking noise coming from the front passenger wheel area, Every time i turn either left or right i get the constant Clunking noise only at low speeds and iv'e also notice Knocking noise when go over a bump now, I have attached a video below looking at the lower are bushing which i'm thinking this is the issue but just need a second opinion before i start buying new parts etc.
[video]https://vimeo.com/user96043084/review/322589517/7a25f45797[/video]
2013-2015 Range Rover Sport
The video does not com up. Clunking is usually from the sway bar link. Control arm bushings make noise when you tap the brake from around 15mph.
I had the exact issue for a bit now and earlier this week the slight knock turned into a horrible loud creaking/squeaking noise. Mine was from the front driver side and I isolated the sound to the sway bar bushing. I sprayed some silicone lube around it as a temporary sound fix and worked. Taking it in to local shop here Tulsa, Ok to replace both of the bushings and will keep updated.
Have the same issue when braking, might be lower suspension arms and or control arm bushings. Lower arms are around £500 a pair fitted. I was quoted £200 for just the bushings.
