1 - 12 of 12 Posts
D
Guest
Hello all,
I am in Denver CO, and heading home to San Diego. I have developed a clunking noise from the front end. Not sure if I should take it to LR here or just wait till I get back. Any ideas of what it may be?
FOUNDING MEMBER
darrinturner said:
Hello all,
I had the same issue.
No big deal.
You just need a new ''stability stang thing'' :wink:
I have 03 HSE with 60K I think I have thae same noise. sounds like tick tick tick but very light.. I believe it's normal cuz I heard other 04 HSE with 15K miles and has the same sound..
Does anybody know where exactly it's coming from?
On mine it makes a clicking, ticking noise when you turn the wheel stopped or low speed. It seems more common when you start out in the morning
D
Guest
Clunk Clunk is different than a click click or tap tap. It might even be a popping noise
Mine is a Clunk Clunk and it happens mostly at slow speeds like take off. I hear it more while turning.
clunk clunk at slow speeds or turning - I had the same thing on mine and it turned out to be a torn sway bar bushing on the driver side - for some reason they replaced the whole assembly and the problem is gone.
1 - 12 of 12 Posts
