This Rover is unbelievable. Once I get one thing sorted, another thing goes wrong.
It has always done this, but nowhere near as bad as now.
It used to fire every time the key got to about 95% of the way around.
Now I need to turn the key 10-20 times before I can find the sweet spot where the connection meet (if that makes sense)
Now it is usually about 75% turn before connection and typically the windows do not work until after it is running, I turn the key back about a hair, literally.
I have been under the dash a few times lately fixing the steering coupler and then the speedo. Did I do something in the wiring, or is the ignition switch toast or....?
Anyone else ever have this problem?
Thank you all for any help. You all have been great on this site
