I brought my RRC back to life after buying it in sorry shape 4 years ago with the suspension on the bump stops and water in the oil. The engine was straight forward with head gaskets and a good tune up. The EAS has been a little more challenging!
The history: I put all new bellows under it after inspection proved they were all rotted. I researched the system and downloaded Ron Storeys awesome reset tool (Thanks Ron!) for Classics and made a cable to connect with the EAS ECU to clear all of the codes. With a few hiccups, got her up off the bump stops. I Had a few codes after that and swapped sensors from side to side to correct that issue. I then proceeded to enjoy riding on air for several years. LOVE it!
Now: I had a hard fault that put me on the bumps for the first time in years. I cleared the fault and she worked fine. Then I noticed that it was working a bit slower and the compressor was running longer and longer. Then I was back on the bumps and when reset the compressor made a terrible clatter. I removed and disassembled the compressor to find the seal gone and the piston and sleeve badly damaged. I ordered up a new compressor, installed it in the box, removed the valve body and cleaned and inspected it.
When I fired it back up it started acting strange and only raised up the right side. The left side stays on the bumps. No codes. No leaks. I am suspecting the valve control unit has gone bad. What do you guy's think?
Sorry this got so long..........
