1 - 20 of 22 Posts
2019 Range Rover Sport SVR
I'm trying to figure out how to wire an aux input to my stock HU. It is a Clarion and I would like to try to solder to the cassette output. I tried to search, but the lack of pictures currently on the site is really not helping right now.
I was also going to try to use the FM output that is featured on a youtube video, but my internals are completely different.
http://www.stockholmviews.com/p38/index.html#clarion although I solder the additional wires to the pins on the back of the board rather than to the back of the socket. If it's just Line In you want, all you ned do is add the cable and ignore the rest about the Bluetooth unit. Use a decent quality screened cable and not the unscreened you find on some cheaper leads or if using a phone on the line in will cause the blick, blick, blick, handshake to be audible. With this mod there's no need to switch to Line In, it will automatically switch over from Radio or Cassette as soon as audio is detected on the Line In input.
Thanks for the link. Unfortunately, the board inside my stereo isn’t the same as that unit. The faceplate is the same. I sure wish this site would get fixed so I could upload pictures.
RIP Our Friend
Please post a photo of your face plate.
All Clarions for the NAS market GEMS should be the same as the Diversity system with cassette was standard equipment. CD changers were optional in earlier years. In 98 the Harmon Kardon speaker system was added to all models with the same Clarion head unit.
Discussion Starter · #6 ·
https://flic.kr/p/294SmLV
It's a '97 with the HK speakers and a CD changer.
Although it looks the same, it may be a different model. There were others that looked the same from the front fitted to the Discovery and also some Iveco trucks. Does it have the model number on it still? It should be LR part PRC7618 (Clarion model PU-9836A).
You could always connect to the cassette head but you'd need to fool the cassette mech to think it had a cassette inserted which might be a problem for you as the mech appears to be faulty (bent spring hanging around doing not a lot in your pics).
RIP Our Friend
If all else fails and you can not source directions for what is different in your head unit... you can send it to the old Roverville Radio. Sadly they, as well as every LR business that had "Rover" in their name, had to change their name when LRNA had fit over name infringement. They are now GB 4x4 Radios. They do spectacular work of going through your head unit and ensuring everything is clean and working properly. Any flaw is rectified. best of all they can add your input to the face and it looks completely factory... no cable and plug hanging somewhere.
http://www.gb4x4radios.com/
Photos
http://www.gb4x4radios.com/aux--iphone--mp3-connection/
Discussion Starter · #10 ·
Mine is rover part # AMR 2672
clarion # pu-9887a
That's one that was supplied by LR as a replacement if the original PRC7618 died. It was never fitted to a car as new but only as a replacement for a Clarion when one was required and was supplied as a kit complete with mounting frame. Presumably stocks of the original one ran out (or Clarion stopped producing them when LR went over to Alpine) so they used a later version as a base with the same front panel so it looked the same. Looks like GB 4x4 is going to be your only option (assuming they are familiar with that particular unit).
Discussion Starter · #13 ·
I gave up. GB 4x4 did not respond to my inquiry. I had an old Pionner HU laying around with USB in as well as bluetooth. The tech support at Crutchfield told me I could not use my existing amps. She was wrong. I used the preamp outputs on the head unit to connect to a Discovery harness adapter. Had to dremel the Metra connector a bit so that the plug would fit. Added a couple of pins to connect the sub and it sounds pretty good.
Phase 2 just happened this morning. I added steering wheel control capability. I was even able to remap the controls so that volume is on the left and tracks are on the right. I still may remap the (nonfunctional) cruise control buttons to the phone.
It may take a while with shipping which will also add to the cost but try contacting Clarion themselves in the UK (http://www.clarion-service.co.uk/cs/Original_Equipment.html). I sent a dead PRC7618 to them. It was repaired, had the Aux in added, the code removed and was back with me within 4 days.
Just thought I'd refresh this thread with what I learned for 2021 about resources and experience in adding an aux input.
For those few of us left with Diversity head unit outfitted P38's...
-If you find you have the OEM retrofit PU9887A head, like me, then you have to solder to the cassette module connections.
-The black wire solder connection in the photo is the fuzzy short one.
-You can simply gut an old cassette casing, (find one that screws together) and shove it in when you want to actuate the aux input connection.
-The signal from my phone ear bud jack is fine. No shielding or filter necessary.
-Watch the on-line video to get the basics for removal and disassembly of the head unit.
-GB 4x4 has a Facebook page, but appears to have not posted anything for a couple years, and hasn't responded to email. So, unless you want to contact Clarion and ship to UK, there's no one that I could find to do this for you.
-Its not that bad. Just be careful and don't force anything. I used my old pencil type soldering iron, nothing fancy, to solder the connections.
-My droid mobile phone with ear bud jack provides great quality signal thru this aux input and will run all audible output for nav, phone calls, and music thru the vehicle speakers. Pretty slick.
  • Like
Reactions: enbruchman
Kraken,
Which photo are you referring? The Stockholm or the Flicker photos..I am trying to do this mod and my diversity unit doesnt look like the Stockholms, it looks like the flicker pics...
Thanks!
Thanks very much for the info, I didn't intend for you to do a search, I thought there were pics already "known". This is very helpful.
No worries! I found this "down the rabbit hole" back when I did the mod. I'd bounced around so much on different links that I'd forgotten this photo was on a Saab forum. Glad you asked cause I had refered to a picture that wasn't part of this thread. 😣
Now it is. 😁
Hope your upgrade goes well!
1 - 20 of 22 Posts
