Again, thank you very luch everyone for your help.
I was reading the forums and noticed a thread stating that the RR should have blue coolent. I checked my rad and the coolent was clear as water but giving a reading that it was good for -40 (very odd). While I was figuring out how I was going to pull off a rad flush (which apparently can't be done by the local Minute Lube because they don't have the tools to remove the upper rad hose) I notice that the canister right beside the rad was loose. The two upper grommits holding this canister had sheered off. I removed the top to securing nuts but couldn't figure out the size of the 'square' nut on the bottom side. Has anyone had to replace these upper grommits, and if so, how did you get the bottom nuts off?
Here is the picture, I will look at the manual to figure out what this canister is so I can call the Local Stealership and order the parts.
