2001.DHSE
So tomorrow I want to check the heated windscreen connections.
I know where they are, but I have to remove the strip at bottom of windscreen. Is there a procedure for this? Please.
Good job to do, I've got the same as the windscreen guy snapped the bolt off! The trim that runs down the side of the windscreen has to be undone, the rubber one thats part of the door seal, wipers arms have to come off too, by then hopefully you can slide the bottom trim to one side. then just follow your nose, the little plastic clips can then be removed and replaced in the strip. sorry guess this won't have helped to much. Think there is a tread some where.
Have you checked the relay for trigger and power output?
