1 - 10 of 10 Posts
92 with 140K miles. Driving around town when I come to a stop the A/C fans slow down and at night the lights dim. As I accelerate away from the stop as the lights and fan come back up to speed the "Check Engine Light" flashes. Has a new alternator.
Bad ground somewhere? Voltage regulator?
RKC, I think the 1992 MY came with the on board display. It is located under your passenger seat and will display codes that could have caused your check engine light to come on. There is a sticky at the top of this forum by Doc Leo on "On Board Display". Hope it helps.
If not, hopefully someone will post up some thoughts. Your description of the lights dimming seems electrical and alternator wiring since recently changes my have become lose. Grounds could be another area to check.
Parker
1993 LWB Plymouth Blue
PS - Congrats on you 2nd place finish at the Car show.
The alternator was replace about a month before I bought the Rover. Hadn't noticed the problem till I started running the A/C.
I have to concur with our neighbor to the south. I would check the connections at the alternator and on the battery. I am amazed at what I find sometimes. The grounds although perhaps less likely are also a good place to check. It doesn't hurt to pull them and clean off the contact points.
You say, it only happens with the AC on? How is the idle when the AC is on? Is she struggling to idle when you are sitting still?
Tach should not read 0. Have you checked your the tension on the alternator belt? When I turn my a/c on I can see a slight dimming of the lights for a moment. I'm with Okie, check your altenator connections and belt tension.
Parker
I'll check the alternator electrical connections. Tach doesn't really follow the rpms they should driving around. Drop significantly when I let off throttle.
Perhaps the alternator belt is so loose that the alternator simply stops spinning at idle? Does the charge light also come on then?
Scott
1 - 10 of 10 Posts
