Thanks everyone. And thanks for the kind words about my website. I wish I had more time to do more.
I may have found the beep bop issue. When I start the rover with my foot on the brake, I get the beep bop chime. When I started her Friday before the drive home, I didn't have my foot on the brake and it didn't sound the beep bop chime. I'm gonna do some more testing.
No codes are being displayed.
I'm thinking at this stage my code display is dead. Before I took the Rover back from my daughter we had a code 69 (gear switch position). When that code comes up you get a check engine light associated with it. I have nothing on the display so I can't rule out that I'm still getting that code and thusly the display is suspect. I'm gonna get a second display and test.
I've reset it. I recently replaced the battery so I know the codes were cleared. When you turn off the engine the check engine light goes off. When you restart there is no check engine light. During drives the light comes on. Sometimes it is not associated with any event, no stumble, nothing. But sometimes it lights when I have a hickup in operation, described in the next paragraph.
On Friday driving home I was about 20 minutes into my drive. The engine and every thing just shut off, and then back on. I was going about 40-45 mph when it happened. It's done this a couple of times before. I thought replacing the coil and checking all the electrical connections and refitting them I would have affected something misbehaving due to a failure of components or electrical paths.
When I got to the next light, she stalled. I slipped it into neutral and started her back up. She ran fine after restart. Next light, same thing. All the way home. Got home sitting in the driveway, I started her and she ran idled like a top for 10 minutes no problems.
At this point,
What is causing the engine to shut off like that?
Why wouldn't she idle at the lights but would idle in my driveway after restart?
I'm wondering how much a code 69 might have to do with a fully functioning ignition. Because if the gear lever switch is in the disable mode like when the lever is not in neutral or park I wonder if it could cause the ignition to be interrupted?
