So check engine light came on again today. Got a code of P04FC. Has anyone had this issue. Can't find any info on it anywhere. Even my cheap scanner says definition is not available please visit website. 2016 RRS TD6.
2013-2015 Range Rover Sport
Hi Joe,
Are you sure this is the right code? I can also not find anything about it.
Similar codes ending in starting with P04 and ending with C:
P049C: Exhaust gas recirculation – B – Excessive flow detected
P047C: Exhaust pressure sensor B – circuit low
P046C: Exhaust gas recirculation sensor A range/performance
P045C: Exhaust gas recirculation B control circuit – Low
P044C: Exhaust gas recirculation sensor C – circuit low. – Circuit low
P041C: Exhaust gas recirculation temperature sensor B – circuit low
P040C: Exhaust gas recirculation temperature sensor A – circuit low
P043C: Catalyst temperature sensor – circuit low (bank 2, sensor 2)
P042C: Catalyst temperature sensor circuit low input (bank 1, sensor circuit 2)
So it seems that the codes with P04 and ending in C have to do with either the EGR or the Cat.
It could be that your EGR is clogged or malfunctioning? or that the Cat is blocked?
Hmm, extremely odd this...
Do you perhaps have a friend close by with a different scanner? You could then check if the code is the same?
2016-2018 Range Rover Sport
P04FCCrankcase Ventilation System Performance
following link is no help
Ive checked this one out but there is no helpful info there.
