While driving my oil lights flickered then it said to shut off engine immediately pulled over did that waited for it to cool checked fluids everything fine started up just fine got to driving noticed that the charging system wasn't working I can read the battery voltage on my deck in the dash Had the battery checked and it was bad just bought that battery so it was replaced under warranty same issue had the alternator tested it was bad bought a new alternator Put it in worked just fine Drove two blocks to the store stopped working disconnect the negative terminal and jumped it to the positive To reset ECU Got it turned the ignition over Allowed system to reset Shut the key off restarted it was working battery light went off but then came back on then went off and came back on and now it's not working again anybody know what the hell is going on
