Has anyone ever done this?
How do you undo the wiper arm? There isn't enough clearance to lift the spindle cover and unscrew the nut, even parking the blade vertically as if you're changing the blade, doesn't give enough space.
Do you have to take the rear spoiler of?
No mention in Rave of how to get this part off that I can see.......
Frustration ensues.......
You do not need to remove the Spoiler as it's welded on any way I think.
If you lift the plastic spindle cover, then slide it backwards and it come's off. You can then undo the 13mm nut (spanner size) that retains the wiper arm. Wiggle the arm and it will release from the tapered spline.
Many thanks Col.
Got a bit fed up trying to remove it, and the missus want's to take the dogs down the beach.
So for now, I've left it disconnected but put back together, I'll give it a go next weekend :thumb:
Col, you were bang on matey :thumb:
Did it today with that useful bit of information in about half an hour.
Thanks :clap:
