It's hard am changing means now I had to buy a new line for connecting line over the oil filter, the problem am having now is the line coming from the engine block the line is stuck in the oil cooler and I used pc blaster and it's still not coming loose.Hey
Plan to do this in the next few weeks as i have an oil leak where the pipe connects, anyone attempted this yet, how difficult are pipes to remove ?
Any advice ?
4.0 v8 96
Becareful because you can broke the fittings in the oil cooler. That's where am stuck at now.It's hard am changing means now I had to buy a new line for connecting line over the oil filter, the problem am having now is the line coming from the engine block the line is stuck in the oil cooler and I used pc blaster and it's still not coming loose.
