Hello,
For the third time i have the EAS fault "pressure contantly high". I alawys remove the error with easunlock software.
I found on the forum that it is a problem with the drive box.
I have a complete eas bloc from second hand but not sure that it's better than mine...
I want to try tu change only the drive box and if possible without remove the bloc from my P38 (under the bonnet work). Is it possible ?
I started to unmounted the drive box from the second hand bloc but there is a sensor (pressure ?) that is directly connect to the drive box.
How i can remove the drive box without the sensor ? ie how to remove the wire form the connector of the drive box ?
Sorry for my bad english, i am a newer owner of a 4,6 HSE P38 and it's only pleasure....
Discussion Starter · #2 ·
Hello,
I have my answer :
1) it is not possible to change the drive box without removing the complete bloc (becaus two screw are unrechable...)
2) i found the way to remove the pin on the connector. First remove the yelow part of the connector (usinge a lever like a screwdriver or other), then with a litle needle push where ther is an arow on the picture and gently pull the corresponding wire.
A few photos :
Yellow Electrical wiring Technology Electrical supply Electronic device
Automotive lighting Light Headlamp Lighting Auto part
