Changing ATF and filter.
1283 Views 1 Reply 2 Participants Last post by  Diggaz
95 Classic.
Going to change the ATF. I'm having a problem finding just plain Dexron II. Will a synthetic or a later Dexron work? On some transmissions you just can't get all the fluid with a home fluid change. Should I expect to drain eleven quarts or some smaller amount?
Do I expect to have to use a bottle jack to push at the frame to change the filter or just make a big mess?
Dex 3 is the replacement for 2 they don't make 2 anymore. Use a bottle jack or sledge hammer 8) You wont get it all out I think some stays in the torque converter but not sure how much.
