Re: Brake Caliper Replaced twice...keeps seizing - 2007 HSE
Changed all four caipers and bled brakes still biding
As you are resurrected an ancient thread with no information of your own there is nothing we can do to assist. We have no idea what year or model you are referring to, what issues you had prior to replacing parts or even what is binding. If you want any assistance you will have to provide more than a shot in the dark one liner.
time to replace all those hoses too... over time or if overheated it can cause internal damage to the hose restricting the outward flow of fluid. You press the brake, fluid flows in to actuate the piston, you're done braking but the fluid can't leave the caliper which causes dragging. Could be more to your issue than that, but it's a good starting point.
