change size from 255/55r19 to 255/60r19 range rover sport 2007
need help i just change sizes tires from 255/55r 19 to 255 /6o r 19 and my car has turn evil on me. i send the to the shop to change tires then,to the respective aliment proses then couple of day later a suspension failure appears. and a (amber color sign drawing of the car whit to arrows ) took back the car to the shop they re aline it. put the scanner on and erase all the trouble codes. but the amber sign still appear after few minuets and the suspension failure in the central console. any help will be hilly appreciate. [email protected]
Re: change size from 255/55r19 to 255/60r19 range rover sport 2007
Tyre size should not create any problem.
Did they maybe damage the compressor when they lifted the car?
No, the compressor is working fine, we did check that whit the scanner. but one time I heard a sound that the one traction control do when is activated. also check the string wheel angel and also seem to be working fine. any idea of what els could it be???. I don't want to be a victim dow hire of our only RR dealership. thanks for your answer at least now i know that the tires are not the problem.
Any one whit any other idea what else should I be looking for??
Please helpme out.
Regards
Can you scan the trouble codes again? What are those codes?
I will and let you Know.
Dos the tire size change matter? There is only a difference between one size and the other of 10 mm:
Tire size has no bearing on operation of the suspension, aside from possibly limiting travel, and causing extended mode, but your difference is no where close to enough to cause that.
No, it shouldn't matter, although the stock size of the 19" tires on the Sport is 255/50R19, not 255/55R19, so by upsizing to 255/60/19 you really increased sidewall height by about 1" / 25mm or so - about 2" in overall diameter - compared to stock. Still, that change alone is no reason for all those errors to pop up. Have you checked to make sure all four tires installed match in size?
