1 - 9 of 9 Posts
Hello,
I'm trying to replace the heater core in my 07 RRS. Does anyone have a link to instructions on how to remove the side panel of the centre console? I have the top off but can't seem to figure out how to get the sides off without breaking something.
Any help much appreciated
IIRC, the sides slide back after you remove the shifter, the fridge box, and undo two torx (one on each side) screws that are in the rear of the side panel near the floor. There is a black plug over each one which pops out.
You have to remove all of the front trim etc. and you will expose some torx screws at the front as well. You have to undo a lot of electrical connections on the shifter and fridge. They are all different and can only go back to the correct plug so impossible to mix up. The rear plugs are tiny vents.
Can you remove the individual sides or does the entire centre console have to be removed as a unit?
the whole unit just needs to slide back a few inches. It is one piece.
Banned
Hello,
It comes out as a complete unit as the chap above stated. Please check the attached image in the hope this helps!
Cheers - Bob :cool:
Hello,
Cheers - Bob :cool:
I know it's a dead thread but any chance you still have this image you mentioned? For some reason, there isn't anything attached to this post.
06 Rover Sport
Hello,
06 Rover Sport
Hello,
1 - 9 of 9 Posts
