1 - 14 of 14 Posts
Hi guys,
My central locking is completely dead. I have checked the fuse which is fine and the fuel cap button works well. Any ideas??/:(
ECU may be fried. I’ve gone through three. All were fried by a leak that I have yet to isolate.
Where is the ECU located?? And are there any ristance tests that I can carry out?
Ah yes that might help 1992
Have you tried the key to both doors passenger and driver
Discussion Starter · #7 ·
Yep none of them work
I saw your other post
On the zone
Usually good stuff there
Hopefully
You get it sorted out
On my 9dtoo
Occasionally the locks don’t work
I manually lock and unlock them
And then the key works again
So
If you manually lock the doors
Do the actuators kick in and lock all doors
Discussion Starter · #10 ·
Na it's completely dead I have a feeling I may not have 12v at the actuator. I'll find out later once I finish work
Discussion Starter · #11 ·
So I have 12v on the connector going to the door lock but nothing on the connection to the actuator. Im guess in the actuator is nothing more that a big switch. Oh and the actuator is the 5 wire one
Ok just throwing this out there
But how about the contact in the door lock itself
Might be a little corroded
Discussion Starter · #13 ·
If it was that it should still work when you push the lock thing down I did give it a nice spray of WD40
Discussion Starter · #14 ·
Does anybody know if the actuator has 12v going to it??
1 - 14 of 14 Posts
